what if i force my L3+ to mine ArtByte?
what if i force my L3+ to mine ArtByte? Penguicoin and those that are above 20 cents per scrypt Mh/s?
should i be more profitable?
Re: what if i force my L3+ to mine ArtByte?
you will only have a "higher" payout when you would solomine.
As soon as you mine PPS all pool profits get split among all users
but if i have a higher hash rate, i should have more share?
yea of course your hashrate matters.
what i meant with "pool profits get split among all users" is the current profitability is the same for all PPS users, no matter what coin they mine.
if you force your miner to mine a specific coin while in PPS, you drop that coins value. if you SOLO mine, you only profit off the found blocks, share earnings are discarded.
You can also mine ArtByte at Multipool.us with scrypt PoW and see the ArtByte pool statistics by visiting https://www.multipool.us/dashboard/pool/aby furthermore, there is a whole guide to mine with BFGMiner --scrypt check out their wiki at http://wiki.multipool.us/mediawiki/inde ... h_BFGMiner
Artbyte works fine on this pool, just the profit for the coin keeps it from being mined all the time.
Way to unearth an almost year old post. I wonder what you do in your professional life.
