Would anybody be kind enough to help me with the setup of the L3+ on prohasing from start to finish ? or point me in the direction of the info.
I can access the miners config page , that's as far as i have got !
Big thank you in advance.
Hi mate, so its as easy as .CritterDog wrote:In the URL type
Then under worker type your user name that you use in the pool
Then under password I use d=16384 n=Put something here to name your miner
Password field is for setting difficulty and to name your miner something uniqe so lets say you want to call your miner L3+ so this is what will show on the main mining page when it is mining you can name it anything you want.. Will use L3+ in this demo.. Here is how you would type it under password.. Feel free to just copy and paste this.copey123abc wrote:Hi mate, so its as easy as .CritterDog wrote:In the URL type
1.Go to interface on L3+ ( i am fully new to ASIC) mined litecoin back in 2013- type in the URL you listed above.
2.Under worker type ? is that my username that i physically login to the pro hasing site with - to be specific https://prohashing.com
3. The password part you sent has confused mesorry !
Should i setup my L3+ to have backup pools or no
CritterDog wrote:Password field is for setting difficulty and to name your miner something uniqe so lets say you want to call your miner L3+ so this is what will show on the main mining page when it is mining you can name it anything you want.. Will use L3+ in this demo.. Here is how you would type it under password.. Feel free to just copy and paste this.copey123abc wrote:Hi mate, so its as easy as .CritterDog wrote:In the URL type
d=16384 n=L3+
And yes you should for sure put in a backup pool.. I use litecoinpool.org myself
The username from the miner setup page and the username from the password string will be different yes ?copey123abc wrote:CritterDog wrote:Password field is for setting difficulty and to name your miner something uniqe so lets say you want to call your miner L3+ so this is what will show on the main mining page when it is mining you can name it anything you want.. Will use L3+ in this demo.. Here is how you would type it under password.. Feel free to just copy and paste this.copey123abc wrote: Hi mate, so its as easy as .
d=16384 n=L3+
Thank you, greatly appreciated. So hopefully i understand fully![]()
URL type-stratum+tcp://prohashing.com:3333
Then under worker type your user name that you use in the pool Same Username from registration on prohashing.com
Then under password I use d=16384 n=Joebloggs123
Looks like you got it.. The user name for the miner that you enter in the password field can be anything you want..[/quote]CritterDog wrote:The username from the miner setup page and the username from the password string will be different yes ?copey123abc wrote:CritterDog wrote: Password field is for setting difficulty and to name your miner something uniqe so lets say you want to call your miner L3+ so this is what will show on the main mining page when it is mining you can name it anything you want.. Will use L3+ in this demo.. Here is how you would type it under password.. Feel free to just copy and paste this.
d=16384 n=L3+
Thank you again.
But user name under Worker must be your registration username for the site[/quote]CritterDog wrote:Looks like you got it.. The user name for the miner that you enter in the password field can be anything you want..CritterDog wrote:The username from the miner setup page and the username from the password string will be different yes ?copey123abc wrote:
Thank you again.
copey123abc wrote:But user name under Worker must be your registration username for the siteCritterDog wrote:Looks like you got it.. The user name for the miner that you enter in the password field can be anything you want..CritterDog wrote:
Thank you again.
