I am happy to be here and look forward to helping others anyway I can once I figure out what I need to do first
About 30 minutes ago I set up my Antminer S9 . I set the url to prohashing.com:3333, The worker is set to my login name. The password is set to n=Jody
My Antminer software says it is working just fine and I am showing that I found blocks. BUT, my prohashing account says, "Miner is using an incorrect algorithm". Also NO Shares found.
How do I change the settings? I assume that Prohashing CAN use the Antminer S9?
What should I do here.
Thanks in advance for you help. I will be online waiting to see if anyone has a solution.
