Solo or PPS?
virtuado
Solo or PPS?
Post by virtuado » Thu Jul 13, 2017 10:26 am
I would like to know what is the best method to use?
I've tried solo for a while, but then it seems nothing is happening much, i understand that block confirmation can take quite some time with solo, but i would like to see some progress....
So for now i swithced back to PPS, but i'm still curious about what's the best method to use.
Please enlighten me?
x10604266
Re: Solo or PPS?
Post by x10604266 » Thu Jul 13, 2017 10:29 am
what coin you mining? if your hashrare is low, dont try solo mode and you're not luck enough . you'll get noting in a very long time
virtuado
Re: Solo or PPS?
Post by virtuado » Thu Jul 13, 2017 10:37 am
I'm mining Dash at the moment with mini-baikal.
