Dash, Algorithm errors - July 4, 2017
Dash, Algorithm errors, Unable to obtain the latest block from the daemon.
Time Is Money
Re: Dash, Algorithm errors - July 4, 2017
UP
Hirocoin
Arcticcoin
Smartcoin
Algorithm errors
Hirocoin
Arcticcoin
Smartcoin
Algorithm errors
Time Is Money
Did this issue occur for a few seconds or was it present for a long time?bbbbbbb wrote:Dash, Algorithm errors, Unable to obtain the latest block from the daemon.
I've heard reports that these errors may be occurring recently, but we don't have anything recording them to the database at present, so we can't track them. That's on our to-do list.
Hours! EverydaySteve Sokolowski wrote:Did this issue occur for a few seconds or was it present for a long time?bbbbbbb wrote:Dash, Algorithm errors, Unable to obtain the latest block from the daemon.
Time Is Money
This is daemons fault. My Dash daemons experiencing the same problems from time to time - I can't get block template from it. Usually lasts 2-5 minutes. It happens 2-3 times daily.
I forgot to reply to this earlier, but what Konov says is true.Konov wrote:This is daemons fault. My Dash daemons experiencing the same problems from time to time - I can't get block template from it. Usually lasts 2-5 minutes. It happens 2-3 times daily.
There is a bug in the DASH client that causes this. We plan to submit a report to the DASH developers, but all pools have this issue.
