Why My hashrate is low than local
x10604266
Post by x10604266 » Sun Jul 02, 2017 11:07 pm
i use a Stratum Proxy in order to use a socks5 proxy to connect site, but i noticed sometimes the acceped hashrate is low than local acceped hashrate about 1/5 - 1/4 (Rejected hashrate is low than 4%) .what can cause this situation? sometime i restart the proxy or miner the hashrate could trun normal.
%both use proxy or direct connect cant avoid this problem
%i use asic miner(A4)
%my password is set 'g=dynamic d=32768'
%the delay i connect to pool is 300ms - 550ms i cant reduce it, my high speed proxy cant connet pool(proxy IP:103.75.117.208), proxy show the ERR: Subscribe response timeout.
Re: Why My hashrate is low than local
Post by GregoryGHarding » Mon Jul 03, 2017 1:39 am
if youre going through 2 proxies youre gonna have latency, which will result in lost shares. try using the regular stratum
also remove that g= command its not needed
vinylwasp
Post by vinylwasp » Mon Jul 03, 2017 6:17 am
Remove both, neither are needed with an A4.
So you connect the A4->Stratum Proxy->SOCKS5->pool, is that correct?
Do you manage the SOCKS5 proxy?
x10604266
Post by x10604266 » Mon Jul 03, 2017 11:28 am
vinylwasp wrote:Remove both, neither are needed with an A4.
Yes, but my network situation is very bad, i'll set up an openwrt router to use a shadowsocks proxy tomorrow to see if it can fix the problem
