Static diff not working
dustind900
Post by dustind900 » Sun Jun 25, 2017 9:55 am
Since the attacks I have not been able to set a static diff. Every time I connect it goes straight to 8,192 (dynamic).
Re: Static diff not working
Post by Steve Sokolowski » Sun Jun 25, 2017 11:21 am
What static diff are you trying to use, and which algorithm are you mining?
Post by GregoryGHarding » Sun Jun 25, 2017 12:14 pm
the static diff minimums were raised a few days before DDosing, if youre using x11 Minimum is 0.016 and im not sure what scrypt is. cant remember the math to convert it. steve will tell you
lilbob
Post by lilbob » Sun Jun 25, 2017 1:57 pm
On scrypt I have been successful with d=1024, d=2048, d=16384, d=32768, d=65536, and d=131072 for 48 hours.
Edit: but not working when i try to do c=coin m=solo also. c=coin and m=solo works alone, but not with d=
Post by Steve Sokolowski » Sun Jun 25, 2017 2:38 pm
Ah, that's a good point. I will ask Chris to lower them.
But even so, 1024 is above the minimum of 512.
JKDReaper
Post by JKDReaper » Sun Jun 25, 2017 5:52 pm
lilbob wrote:On scrypt I have been successful with d=1024, d=2048, d=16384, d=32768, d=65536, and d=131072 for 48 hours.
If the coin is low difficulty and you try too high, the system will override it, to lower it..
dustind900
Post by dustind900 » Mon Jun 26, 2017 2:24 pm
I'm mining scrypt with a gridseed. 1024 will not do. I need to set it at 512 which does not work.
This blows because the price of scrypt is up and I haven't been able to mine here since the attack.
Post by GregoryGHarding » Mon Jun 26, 2017 4:25 pm
go dynamic and give it time, it will eventually hit the most profitable diff
lilbob
Post by lilbob » Mon Jun 26, 2017 6:43 pm
dustind900 wrote:I'm mining scrypt with a gridseed. 1024 will not do. I need to set it at 512 which does not work.
did you say 1 gridseed? like 1 Orb? that is 377kh/s base, you should try to use simple c= arguements at that level. like c=iloveyoucoin. the other coins may be out of your difficulty range
n00bminer
Post by n00bminer » Mon Jun 26, 2017 7:39 pm
Gridseed blades will do 1024, although best is 512 or 768
