WAMP compression enabled
Chris discovered a few minutes ago that WAMP supports compression. Crossbar, the WAMP server we used, has compression turned off by default, so we enabled it and restarted Crossbar a few minutes ago.
The bandwidth usage declined by 95%. Feel free to reply and comment on your experience with the live data.
Re: WAMP compression enabled
Will that help to catch up all the shares from all day today that haven't credited?
Either way it's a huge gain from compression, great news.
Chris will look into this, but I'm not sure exactly what the symptoms of this problem are. Are there rejected shares? I know that the database was behind earlier, but it caught up.FRISKIE wrote:Will that help to catch up all the shares from all day today that haven't credited?
Maybe Chris has already found more information. I'll go ask him.
Oh good god yeah there rejected shares all day, moment I'll attach an example of what I've been dealing with . . cant figure out how to post it here, I'll send it to contacts@prohashing.com for now . . thanks for follow-up
It's been a HORRIBLE day for mining and BitConnectCoin offline all day!
June 21 was a horrible day for mining, low profits please check if all shares were credited.
June 22 was a horrible day for mining, low profits please check if all shares were credited.
June 23 was a horrible day for mining, low profits please check if all shares were credited.
What has happened to the Mining Server?!?
What was changed? good god it's back to behaving so bad as to be useless for NH!
https://ibb.co/mQwwa5
Jesus Guys - PLEASE TURN OFF WHATEVER YOU TURNED ON!!!
You absolutely totally killed the server performance!
https://ibb.co/f5UooQ
Ever since switching on that freaking compression, and . .
Yet again you guys make significant change to system behavior then just freaking disappear!!
