2FA quirk. Payout addresses attempt to load page before authentication
Payout addresses attempt to load page before authentication which results in a popup error "error loading payout addresses"
Re: 2FA quirk. Payout addresses attempt to load page before authentication
how do you arrive at this error, my payout addresses load fine in the settings with 2FA on
It is a popup window error message that goes away on its own.
are you using chrome. im using chrome and got nothing, even changed and saved my addresses
I'll logout and test again. It popped up so fast (2x) but then went away as I finished the authy. Stand by =)
Nothing this time! May have been just the very first time, chrome trying to help out with some cached nonsense.
It could also be PEBKAC, it has been known to happen =P
glad you sorted it out
