Help with earning?
Help with earning?
Hello,
I have been mining for Prohashing using the GUIMiner for ATLEAST 2 hours now but the earnings page on the site has not changed at all. I feel like I am not getting paid and I am wasting my time right now so please help me sort this otherwise I'll just have to stay with Nicehash. I have earned atleast 900 shares but NOTHING has been recorded on the earnings page. It tells me that Im mining and what im mining but nothing that I actually want.
Thanks.
Thanks.
Re: Help with earning?
make sure your miner and password args are set properly so you and the mining server know if your mining x11 or scrypt
first thing to do is post your config
youre trying to mine Bitcoin (sha-256d) prohashing only supports Litecoin (Scrypt) and Dash (X11) algorithms
What program should I use then?
I have Nicehash but i don't know how to set it up for this
are you CPU GPU, or ASIC mining
GPU, GTX 970
url= prohashing.com:3333BaylissLad wrote:I have Nicehash but i don't know how to set it up for this
Worker= [your PH username]
Password=[see below]
if your mining litecoin, doge, etc (scrypt)
password: d=8192 g=off h=1000
if Your Mining Dash and other dash altcoins (X11)
password: a=x11 g=off d=0.1 h=1000
if you still want to use your GPU to mine here aswell you will need cudaminer for NVidia Cards
https://github.com/tpruvot/ccminer/rele ... .0-tpruvot
How do I actually change those settings though? I really can't find it
