NiceHash negative delta
AvPro
Post by AvPro » Tue May 23, 2017 6:17 am
Hello,
I'm mining on here with hash from NiceHash. I have read The help documentation and other forum posts regarding minimising negative delta.
I am using password parameters g=off and r=0.5 , I've tried both together and both seperatly. Always with static diff param too
I still get about ~6% negative delta for what I am paying for against what is being recognised at the pool. Usually this is always a little bit positive delta or close to zero.
Anything I should be doing to fix this? It's quite expensive to "play" with the parameters as regardless I get charged an order set up fee by NiceHash
Thanks
Re: NiceHash negative delta
Post by Steve Sokolowski » Tue May 23, 2017 7:08 am
AvPro wrote:Hello,
Thanks
The "r=" password argument has been eliminated.
Use "h=" instead. Try starting with 1 and increasing until you find a delta that is minimized. Keep h= as low as possible, because if you get too high, your miner won't be able to be assigned to lower difficulty coins, and if there are no other miners available for those coins, you will lose some profit.
AvPro
Post by AvPro » Tue May 23, 2017 9:43 am
Thanks,
Is it correct that g=off and h= can be used together?
I'm using h of 1 and g=off and it's now 4% to 5% negative. I will increase a little more
