solo mining rewards not shown
spauk
Post by spauk » Thu Apr 27, 2017 4:11 pm
I've been trying to solo mine some minor coins like debitcoin and vegascoin. I see solved blocks in the solved blocks portion of the earnings page and they've matured, but live balance hasn't increased by the block reward amount. Vginacoin works well when the daemon is up and running, sometimes it seems to crash and not accept any connection.
Re: solo mining rewards not shown
Post by Steve Sokolowski » Thu Apr 27, 2017 6:47 pm
spauk wrote:I've been trying to solo mine some minor coins like debitcoin and vegascoin. I see solved blocks in the solved blocks portion of the earnings page and they've matured, but live balance hasn't increased by the block reward amount. Vginacoin works well when the daemon is up and running, sometimes it seems to crash and not accept any connection.
Thanks for the report. I'll forward this one on to Chris and he'll take a look tonight.
Schneisele
Post by Schneisele » Tue May 23, 2017 2:24 am
I have the same problem
spauk
Post by spauk » Thu May 25, 2017 1:56 pm
I'm still having an issue with this. I tried solo mining bata and saw 7 solved and matured blocks (and one orphan) overnight but the live balance doesn't show it. I'm hoping it's just slow or something, which seems odd because the site does seem faster and mining more stable after the improvements yesterday.
Post by Steve Sokolowski » Mon May 29, 2017 9:00 am
spauk wrote:I'm still having an issue with this. I tried solo mining bata and saw 7 solved and matured blocks (and one orphan) overnight but the live balance doesn't show it. I'm hoping it's just slow or something, which seems odd because the site does seem faster and mining more stable after the improvements yesterday.
The live balances will not show the updates in real time for solo blocks. This is a known issue that we have a bug in our task list to fix.
However, you can refresh the page with F5 for now, and you should see the balances credited as normal. If I'm misunderstanding the problem, feel free to contact Chris at contact@prohashing.com and he can help you troubleshoot.
spauk
Post by spauk » Mon May 29, 2017 6:34 pm
i think it's more than just the live balance not updating, the payout amount was short like it was using PPS even though it was supposed to be solo. i won't contact chris about it if he has a lot on his plate already. i will probably just avoid solo mining until it seems to work right
