Forfeited balance - In the last days
In recent days, all my earnings, has been marked with the "Forfeited balanc".
-223.00775095 Forfeited balance 23/04/2017
-80.18011843 Forfeited balance 22/04/2017
223.00775095 Payout on 23/04/2017 22/04/2017
-55.94663111 Forfeited balance 21/04/2017
80.18011843 Payout on 22/04/2017 21/04/2017
-329.99816975 Forfeited balance 20/04/2017
55.94663111 Payout on 21/04/2017 20/04/2017
329.99816975 Payout on 20/04/2017 19/04/2017
Can you see what's going on and correct the situation?
Thanks
Thanks
Re: Forfeited balance - In the last days
Any feedback, about this situation?
I'll have Chris look into this issue. Are you renting hashrate from a cloud mining provider? It's possible that they are ripping you off with "low luck miners," and that triggered the forfeitures.joker_josue wrote:Hi,
Thanks
No ... I use a mineral of my own.Steve Sokolowski wrote:I'll have Chris look into this issue. Are you renting hashrate from a cloud mining provider? It's possible that they are ripping you off with "low luck miners," and that triggered the forfeitures.
Since the day 19th, all profits have been withdrawn.
I turned the miner off, waiting for the situation to normalize.
- Chris Sokolowski
- Site Admin
I apologize again for the issue. This was a bug related to X11 mining. I have fixed the code and refunded yours and all others' forfeited balances since the upgrade. You can go back to mining and, as long as you aren't withholding shares (I doubt you are; you would have had to modify your miner) your balance will not be forfeit again.
Thank you for your help! I'm going back to mine. Thank you.
