Aware of share delays
Chris is aware of the delays in computing statistics and inserting shares into the database. He will fix the issue within a few hours.
In the meantime, all profits are being tracked, just not displayed, and no money is being lost.
Re: Aware of share delays
OK. Glad to see you coming. Hope the issue will be solved soon.
Waiting for a quick solution
1MH/s/day just for a simple Shall be a minimum of 200,000 Satoshi
an entire day's pay was gone completely as about compensation????
OK so is the issue of share recording fixed? It seems as though its not showing earnings from last night. My miner mined all night and did not go to a failover pool so I would expect to see more shares. Will this be corrected or did the pool have a failure? Not impressed with the communication regarding this issue.
I apologize for the problem.Advanced1 wrote:OK so is the issue of share recording fixed? It seems as though its not showing earnings from last night. My miner mined all night and did not go to a failover pool so I would expect to see more shares. Will this be corrected or did the pool have a failure? Not impressed with the communication regarding this issue.
This issue is fixed in the x11 version of our server, which we plan to release on Sunday. Until then, Chris has computed how much money is owed and will increase balances within the next hour.
