Problem with CGMiner
I tried to add prohashing pool to CG Miner. It says "No Stratum, GBT or Solo support in pool 0 http://prohashing.com:3333 unable to use".
Seems I'm doing something wrong. Help me with settings please
Re: Problem with CGMiner
again... pool is broken..
- Chris Sokolowski
- Site Admin
There was an issue with our router tonight that was causing some miners' connections to be rejected. I have fixed the problem. You shouldn't have any more issues, but I will be happy to help if you still need assistance.
Ok, thanksChris Sokolowski wrote:There was an issue with our router tonight that was causing some miners' connections to be rejected. I have fixed the problem. You shouldn't have any more issues, but I will be happy to help if you still need assistance.
It is still occures.
Maybe it is something wrong with my .conf file?
"pools" : [
"url" : "http://prohashing.com:3333",
"user" : "***",
"pass" : "***"
"failover-only" : true,
"no-submit-stale" : true,
"api-listen" : true,
"api-port" : "4028",
"api-allow" : "W:192.168.1.0/24,W:127.0.0.1"
I'm not aware of what Chris did exactly, so unfortunately I'll have to defer to him to answer this question.
He has a Toastmasters event this afternoon, so he should be able to get back to you in about eight hours.
- Chris Sokolowski
- Site Admin
Try changing the url to "stratum+tcp://prohashing.com:3333" I think if you don't put that, it uses the inefficient getwork protocol, which we do not support.
