Nicehash Incompatible
soundposition
Post by soundposition » Sat Feb 04, 2017 8:08 pm
Nicehash says your pool is incompatible, what's the problem??
Notice: Pool verificator may may not be 100% accurate and may report pool being compatible while in fact it is not compatible or vice versa. Always discuss with pool operator if you encounter any issues with the pool verificator.
Pool host: prohashing.com
Pool port: 3333
Pool user:
Pool pass:
Algorithm: Scrypt
Resolving pool host prohashing.com... OK
Establishing connection with proxy... OK
Establishing connection with pool 98.115.147.74:3333... OK
Sending mining.subscribe... OK
Sending mining.authorize... OK
Error: null
Your pool is shown as incompatible therefore we encourage you to contact pool operator to make sure that the pool is using minimal/starting pool share difficulty which is compatible with our service (and thus compatible with today's miners), please send them link to our FAQ on this topic: https://www.nicehash.com/index.jsp?p=faq#faqb3. Thank you!
Site Admin
Re: Nicehash Incompatible
Post by Chris Sokolowski » Sat Feb 04, 2017 11:54 pm
This isn't indicative of a real problem. NiceHash throws the error if the initial difficulty of a pool is less than 8192. Ours is 4096, and the automatic difficulty adjustment will increase the difficulty as necessary for faster miners.
