Electricity settings - wattage
Hi, I just had a quick question about the settings page for electricity cost and wattage. Is that setting for wattage the wattage per individual miner or the cumulative wattage of all the miners that are mining? Thanks.
- Chris Sokolowski
- Site Admin
Re: Electricity settings - wattage
The wattage right now is for the total power of all miners connected to the account. In the future, we plan to change power consumption to be per-worker, specified by a password argument, which will likely be after we get out multiple algorithms.
Cool, Thanks for the quick reply. Sounds great on the per worker consumption in the future. This is really a handy tool and it helps a lot with figuring out what is going on at a glance. Keep up the great work!
