Need help with Nicehash
Maznoz
Re: Need help with Nicehash
Post by Maznoz » Thu Oct 29, 2015 12:03 pm
They say the following about minimum difficult when creating a new order:
Minimal pool difficulty: 1024 => 8192
No idea what it means, since 1024 seems to be too low. When using 8192 as a fixed difficulty there are no issue.
However, this is what their pool verificator says (seems to indicate that 1024 should work):
Resolving pool host prohashing.com... OK
Establishing connection with proxy... OK
Establishing connection with pool 98.115.147.74:3333... OK
Sending mining.subscribe... OK
Sending mining.authorize... OK
Received mining.notify subscription... OK
Received mining.set_difficulty... Pool difficulty too low (provided=16, minimum=1024)
Waiting for pool to send higher difficulty.
Received mining.notify work... OK
Received authorization result... OK
Post by Steve Sokolowski » Thu Oct 29, 2015 2:33 pm
That's due to the work restart testing, which Nicehash doesn't support. You can use r=0.5 to get rid of that error. Or, you can wait 60s, after which the pool will detect there is an issue and skip the testing.
