L3 Miner Very Inefficient
Re: L3 Miner Very Inefficient
Ya same here...missing like 1.5-2 LTC at current daily averages and the time of the day.
Thanks for that reply. Just got started today and was a bit surprised about the earnings too, to say the leastJalapan wrote:he means stale shares/shares not counting properly or something similar.. and the brothers that run this pool always take care of 99% of the errors.dog1965 wrote:huh what do you mean ?
most likely we will be refunded etc
I dont know why but it works for me try to stay low on the diff seems to work much better dont go lower than 2048 though.
Do you look up the different numbers of diffs somewhere, or is it pure trial and error?
pure trial and error.
Support got back to me:
I apologize for the issue. From September 28 at 7PM (ET) to September 29 at 5PM (ET), the mining server experienced a bug and was crediting people less than they deserved for high difficulty shares. We have fixed the bug, and I just increased user balances for those two days proportionately to how they were affected. As always, please feel free to contact us if you have any other problems.
Sincerely,
-Chris Sokolowski
Manager, Prohashing.com
Sincerely,
-Chris Sokolowski
thanks chris. keep up the good work.
Ok I have a question.  Current miners are running at  d=131072
Miners
molitar.1 ~463.52 MH/s
molitar.2 ~480.78 MH/s
molitar.3 ~581.33 MH/s
molitar.4 ~508.40 MH/s
3 and 4 are consistantly higher than either 1 and 2. Does this mean my d value would be incorrect for 1 and 2 and if so any suggestions which direction?
Efficiency 93.33% but only running about an hour so far so waiting to see if that goes up anymore.
						Miners
TRY bringing 1 and 2 lower see what that does what type of miners are they l3+'s if so not all units run at the same speed no matter which pool you on but like I said bring down d= on 1 and 2 see what that does.
Ok is there best practice for how much to bring it down? like 1/8th, 1/4th, etcetera?dog1965 wrote:TRY bringing 1 and 2 lower see what that does what type of miners are they l3+'s if so not all units run at the same speed no matter which pool you on but like I said bring down d= on 1 and 2 see what that does.
Second approximately how much should I make with 4 of these miners daily currently?
