L3+ 08 firmware
Re: L3+ 08 firmware
Hashingpro, Thanks for your reply... I tried customizing the fan speed percentage, entered 95% and 90% and they seemed just as loud, just a bit slower. Did I do it wrong? Everything was good with the 8/9/17 filesystem version. I'd still like to find a copy of that firmware
Re: L3+ 08 firmware
I checked and all I had was 420(hehehehe) and the 8-25, I cant find 8-9 and I thought for sure id save it to be safe.
maybe the one in between was a bad one and got erased? or there wasnt one and we just thought there was some other early august version I cant find anywhere?
Yeah once those miners get up to speed they sound like mini vaccuums.
Re: L3+ 08 firmware
How do you adjust the fan speeds to 90-95% etc on the L3+?
Re: L3+ 08 firmware
You go to Miner configuration page and there you can adjust itAceman wrote:How do you adjust the fan speeds to 90-95% etc on the L3+?
